evolution 40 hesitation
Hi all. away from home for work. Last weekend I took my trainer to the field to fly (easy2) The Evo engine will slightly hesistate when going from idle to full throttle. it flies fine, but I worry about the engine dying. I've tried adjusting the high end mix, but no real difference. Only seems to do it after idling on the table for a while. Once I'm at full throttle and then go back to idle and then full throttle again, it's fine, not hesitation. Should I worry or just fly/!
TIA
