1. If the secondary antenna is damaged on arrival. I can replace it. I just need your order number. Yes a little soldering will do the trick.
2. Yes this radio doesn't have programming input from the TX itself like the famous DX7. You programming must down on laptop and transfer to TX via USB cable.
3. Xheli.com is the best seller to get replacement parts for this heli. Xheli.com is located in USA.
4. Since you are a beginner I say you are way ahead of yourself for now. You should just pratice alot with simulator and learn to fly this heli before getting into upgrading.
Andy
ORIGINAL: gemello
Hi Kevo 450 and all the other friends which they know this helicopter and this radio,
I have just received the genesis 450 pe and I have some problems:
ì1.The small antenna of the smallest second remote receiver is detached as soon as I have touched it and I have lost the the piece of electric wire that is detached.
What do you think if I try to open the receiver and I try to solder an electric wire? And in this case I have to use a specific electric wire?
2. Seeing with the computer the transmitter setting, there are things that seem to me strange and I would like to know what you think about this fact.
Swash Afr: Ch 1 -50; Ch 2 -50; Ch 6 -80
End point Ch 5 120 and 120
Sub trim Ch1 -40, Ch2 +70, Ch4 +60, Ch5 -50, Ch6 +40
Seem to me that instead of regulating the hardware of the helicopter, has been setted only the input of the transmitter with the laptop.
3. Which are the on-line best sellers of spare parts for this heli? In USA? in Canada? In Far East?
4. What are some of the best servos ballraced that I can buy? What are some of the best servos ballraced that I can buy for the tail?
I am in serious problems because I am a beginner, Italian, living in Colombia where I don't find anybody experienced.
Thanks and regards
Gemello
