RE: Flycat 71 nitroplanes
If you can program a mix in there just slave the ailerons to the elevator at the proper (+)(-) reaction to the up or down deflection of the elevator. If you can put it on a switch then you can experiment with it. Just make sure the ailerons still work while the mix is activated too.
