This comes up a lot in this forum. New Era Models sells a big block conversion kit.
http://www.neweramodels.com/cgi-bin/...0#?session_id=
If you do this you will likely start to break differentials and other tranny parts as well if the engine you install is a lot bigger than the G3 you will change the balance of the truck since its mounted to one side.
