RCU Forums - View Single Post - A/R same engine, area, . . . .same everything. How much difference will higher A/R..
Old 06-25-2003 | 03:29 AM
Jeremy Sebens
Default Re is important!
In many cases, the profile drag increase from dropping the Reynolds number can outweight the induced drag benefits of a higher aspect ratio. This is part of what influenced the results on gliders quoted before.
For instance, if we start at Re=200000, and double the aspect ratio, we will recuce chord, and therefore Re, by a factor of 2.
For a sample airfoil, this increases profile drag (Cd0) from 0.01 to 0.014, which will significantly reduce top speed, as well as attenuating the turning benefits of the higher AR.
It's a very complex and mission-dependent problem, and increasing AR may very well help you, but I just wanted to point out the physics behind some of the drawbacks to high-AR wings on models.
Above about Re=300000, these evvects become almost negligible. Below Re=100000, they are incredibly important.
