Hey Bill,
I don't know if you remember the trailer that I was in back at Tangerine in Dec. 08. That trailer is a fith wheel type I think its around 35 to 38 feet long and weighs close to 15,000 lbs. My father's truck is the Ford diesel and if you stay around 70 on the interstate you get between 10 and 11 miles to the gallon. Wind resistance is the biggest factor verses weight for the fuel milage. I'm not sure what engine you are running in your truck, but the bigger engines available in these trucks would be the best to use pulling campers because they will not have to work so hard as a smaller engine. This usually result better fuel milage while pulling your trailer. I know my father's truck get about 17 mpg when it's by itself and on the interstate, but is kind of gear bound for heavy pulling. I know I enjoy using my father's truck and trailer when I go to these contest and you get that kind of home away from home feel.
Thanks for coming down to my contest and it was good to see you again. We will have this contest again in Febuary of 2010 and I hope you get to come again and with your new fith wheel toy hauler.
Larry Odom
Avid Kool-Aid Drinker
