RCU Forums - View Single Post - Redrilling firewall blind nut tips???
Old 05-01-2009 | 02:29 AM
MetallicaJunkie's Avatar
MetallicaJunkie
Default RE: Redrilling firewall blind nut tips???
if the motormount you are using is a perfect square you can just rotate it, and the thrust line will remain the same.,, Some motor mounts are perfectly square others arent, hopefully you'll get lucky
