RE: SV 27 VS. FASTECH HELP
4S is all id recommend in the sv as far as voltage. But you can run as many in parallel as you like. It's just more capacity. People dont' usually do it because it adds weight and is expensive but it also in cases where you run 2, 4S cells in parallel it may be a realistic combo.
