RCU Forums - View Single Post - leaking fuel
Thread: leaking fuel
Old 05-01-2009 | 07:05 PM
ilanstylz
My Feedback: (12)
Default RE: leaking fuel
You need to check your manifold, which is the piping that is attached to the engine, on there is a gasket that sits between the engine and manifold, if that is damaged or no good it may cause leaking, and make sure the bolts holding it onto the engine is tight, and this is what he means by sealing your engine for air leaks:
http://www.savage-central.com/module...wtopic&t=54465
