RCU Forums - View Single Post - Problems with AFPD on new PC
Old 05-02-2009 | 02:44 PM
BuschBarber
Default RE: Problems with AFPD on new PC
I forgot to mention that I had originally installed the latest Nvidia driver when I first set up the PC. I just checked and it is 182.50 for the XP 64bit OS. Now when I installed the program, successfully, as outlined in the previous post, I first installed the Main Program and then the 1.11 patch. I checked to see how the program worked after each Addon was installed. I reinstalled the 1.11 patch after all the Addons were installed.
I did notice, today, that while I was running AFPD, the HDTV went blank again . It does not seem to do that when I am running any other program. My PC case has a 280mm Cooling fan on top and a 120mm Cooling Fan on the Front and Back.
