RE: Center of Gravity question.
I drilled 2, 1/4 inch holes in the skid under the tail, In those holes I placed 1 inch bolts with a nut and washer on each side,so 2 bolts, 4 nuts and 4 washers. I now have the center of gravity with an empty tank perfectly at 4 inches from the LE the recommended starting point. I have already cut and covered another skid to replace this one once my lead order shows up. I ordered several weights last night. I actually have some around here somewhere but I can not find them for my life. I want the stuff inside the fuse but what I have will work fine for now.
Thanks for the help everyone.
Now if I can get the wind to lay up I will go fly this sucker.
