RE: How can an ABS glued hull be split?
Could sand the inside where it is with 80 grit sand paper and use epoxy reson with the carbon fiber cloth..But you could also get perma poxy plastic epoxy from advance autoparts.. Works great with plastics and fiberglass and metals..could sand it what I said without adding carbon fiber cloth and just spread the perma poxy on the seams..
