RCU Forums - View Single Post - How can an ABS glued hull be split?
Old 05-03-2009 | 07:58 PM
misshydro's Avatar
misshydro
Default RE: How can an ABS glued hull be split?
heres a better idea?? You could use a die grinder with a cutoff wheel on it or a air cut off tool and ease the trigger and cut down the seam with it and then sand it..heat gun might melt it to qickly..
