RCU Forums - View Single Post - How to trim out a plane?
Old 05-04-2009 | 11:50 AM
Bob Mitchell
Default RE: How to trim out a plane?
ORIGINAL: quore
Just got my Hangar 9 Pulse XT 40 built and I am working on breaking in the engine. I figure i will get it in the air by next weekend, and I was curious how trimming everything out is supposed to be done. When you get the plane into the air, do you adjust the trim when at full throttle?
One thing to add to what has been said above........
If you set your linkages up properly, with the servos centered, the surfaces themselves centered and the trims on your Tx centered, hopefully the in-flight trim adjustments will be minimal. If I have to make significant trim adjustment in the air, I usually readjust my control surfaces so that they are at their trimmed position with the Tx trim settings near neutral. This will require noting the relative position of the surface, neutralizing the trim control and then adjusting the clevis to put the surface back at it's noted relative position where it needs to be for straight and level flight. It's not absolutely necessary, but I prefer to have my trim settings within a few clicks of neutral with the plane properly trimmed. If you're way out near the end of the trim adjustment you're probably better off making the mechanical adjusment and then flying the plane again to finalize your trim settings. I think it's a good habit to get into.
Good luck with your plane.
