RE: servos jumping
Ok, you really should try and figure out what is going on here. First thing to do is pull all the radio gear out of the plane and set it up on the bench to see if it still does the same thing outside of the plane. If it doesn't then you know there is something about your installation in the plane that is causing. If it still does it then the issue is with the radio.
Ken
