RE: Add on #5- crashes why?
1) Tell me exactly what kind of hardware you have, especially 3D graphics card, CPU, and any other hardware installed, sound card etc. Factory Installed sound card (not very good one, basic), Dell Insprion 1737, Intel Core Duo CPU P8400 @2.26GHz, Vista service pack 1ATI Mobility Radeon HD 3400 Series (something along those lines)
2) What is the RAM size? 4.0 GB
3) Which operating system are you using, XP or Vista? 32 bit or 64 bit? 32 bit Vista
4) Tell me exactly what drivers you installed for the 3D graphics card.
5) Which addons do you have? 3 and 4 (5 cannot add)
6) What is the version number printed on your main AFPD disk? 1.8.0.9
7) How did you install the main disk, addons, and patch (which version?), and what was the sequence of installation? Inserted the main disc and followed instructions, then proceded with the Add On discs
8) Pls post your tm.log file which you can find in the following directory
afpd-a033.tml - 10-16-2007 - TML file 1KB
afpd-a034.tml - 11-7-2007 - TM file 1KB
afprod.tmd - 11-5-2004 - TMD file 3KB
I currently have Version 1.11.7.7 installed - I try to update the version to 1.11.07.21 - but fails to load and gives me a series of error messages....I do have those saved in power point, I can e-mail those if you like? I noticed on the Add On 5 that the version number on that disc is 1.11.07.19 which is not available on the AFPD site.....
