RCU Forums - View Single Post - Problems with hovering
Old 05-05-2009 | 01:10 PM
ameyam
Default RE: Problems with hovering
Lets take it one by one.
A 14size prop will hit the ground on our rather bumpy field. Also, the landing gear is a bit short
Everytime I open the cowl (once every two weekends) to scrub the engine, I have to remove the needle and hence I have to adjust it on field everytime. So if it was possible to correct this that way, it would have already happened.
Not Likely the engine is overheating I scrub it clean with soap externally every second weekend. The clunk has not fallen off.
Am attaching the photo of the cowl to indicate openings
I have ordered a dubro tank and it will be here before the weekend. I will try to get it in this weekend and check
Basically what I am asking is, should the tank be mounted any other way and is this engine suitable for 3D?
Ameya
