RCU Forums - View Single Post - planes turns right
Old 05-05-2009 | 02:37 PM
Stickbuilder's Avatar
Stickbuilder
Default RE: planes turns right
ORIGINAL: mshay
ok ok who cares about hey im smarter then you and have more experience then you. i dont want to read about hey im more experienced then you, what are you guys teenagers.
listen to what im typing
i take of the plane will dip the right wing down, have max'd out the trim on wings and even put in trim in the rudder. with out putting in any turning input it will dip the right wing/turn right
i put on wieght to try to keep it from doing this but it still does it, and i put on a substantial amount of weight to the left wing. put a heat gun to the wing to try and fix a possible warped wing.
everything i have done doesnt fix it. is this a lost cause? should i give up and just hang it on the wall?
'i would like to keep flying the plane, its kinda nice looking and i like it but not willing to crash it beyond repair.
One other question comes to mind. Are you sure that you are not deflecting your rudder stick when advancing the throttle. It's easy to do.
Bill, Waco Brother #1
