RE: SC 120 ringed 2 STROKE toubles
Plug Im using is an OS No 8, the nose on both engines Im shure is no something else, if is under load is ok if you release the throttle is ok is just when you are cruising a middle stick, in the bench does the same, could be the worng plug or fuel?
