RCU Forums - View Single Post - BME 50/Bosche shielded cap - is this possible?
Old 06-18-2003 | 05:57 PM
Antique's Avatar
Antique
Default BME 50/Bosche shielded cap - is this possible?
Spark plugs with the tops cut off are for the ignition caps on the foreign igitions that come with the ZDZ engines...If the thread in the cylinder is 14 mm you can use any resistor plug that fits and screw the Bosch cap onto the end of the wire, and solder the ground strap to the cap....
