RCU Forums - View Single Post - Designing a "P-38 Stick". Need input
Old 06-18-2003 | 04:03 PM
TLH101's Avatar
TLH101
My Feedback: (90)
Default Designing a "P-38 Stick". Need input
Ok, here goes. I have a complete in good shape wing from a Model Tech "Joss Stick". It is a sheeted foam core with a 67" span, 14 1/2 cord, & about 877 sq ". I am planning a relative layout about the same as a full scale P-38, but with all the "Ugly Stick" outlines . Booms will be 24" apart, and about 45" long(prop to rudder tip). Center pod will be about 25 1/2" long, and stab span will be about 29" with a cord (inc elevator)of 6" I am planning on 2 .40's for power. What I really need to know is where is the best point for the thrust line and stab C/L in relation the wing C/L. I am not refering to incedence, as it will be 0-0 on wings & stab, and about 2 down on motors. I am more interested in distance above or below the wing. I am thinking the stab should be just slightly above the wing, and the engines just about 1"-1 1/2" below wing C/L. Wing has about 1 1/2" dihedral at each tip and has strip ailerons.
Most important factor in this design will be "KISS".
So lets have some opinions and ideas.
