RCU Forums - View Single Post - Sig Rascal 110
Old 05-06-2009 | 07:02 PM
  #308
pittsman
Default RE: Sig Rascal 110
Mike
on my G26EI, i use a 18 x 6 wood Zinger and lawnboy32:1 mix with mid grade fuel only. the low grade fuel in this area has to much alcohol in it that will mess up the carb. i found that out from a buddy that runs a small engine repair shop, he says that prolonged use of the cheap fuel will weaken the important parts of the carb...gaskets...etc. I also tried some 115 racing fuel, but did not notice a gain in power, just a cleaner running engine and a odor that reminded of the local racetrack that i use to go to. I put alot of faith in the products that i use!!
Eric
