RCU Forums - View Single Post - Binding two 2.4 receivers
Old 05-07-2009 | 08:24 AM
chris1971's Avatar
chris1971
Default Binding two 2.4 receivers
I've got a good one for you radio guru's. I am building a jet that I want to run two spektrum receivers in. I know everybody tells me it's unnecessary but I want to do it for my own piece of mind. Now when I bind two 6200 receivers together everything works fine, but I need more channels so I bought a ar9000 for the main and was going to use one of the ar6200 as my other side since it will only be running one side of control surfaces. When I bind the ar9000 and ar6200 everything gets crazy. One or the other will bind correctly(whichever binds first) and the other the bind lights come on, but when you move the sticks you only get elevator and rudder movement . The really wierd part of the whole thing is that left aileron stick input gives you elevator movement and right aileron input gives you rudder movement. The other receiver works perfectly. I have bound each receiver seperately and they work fine and I tried binding two different 6200's to the 9000 and still get the same result. Any ideas?
Chris
