RE: Adding After run without a crank vent
When you put oil into the cylinder, it can prevent the engine from turning over. You inject after-run oil into the fitting that's on the back of the cam case. Just pull the tubing that goes from there to the intake manifold, and add your oil into the crankcase at that point.
