RCU Forums - View Single Post - Kick back
Thread: Kick back
Old 05-07-2009 | 10:00 AM
airlyons
Default RE: Kick back
Anyone know why the electronic ignition has to be set at between 28-32 degrees BTDC when setting it by turning the prop? You would think tha when turning the prop by hand (at a slow rpm) the electronics would be sparking it for an idle rpm which would be close to TDC. At high rpm the spark ignites at 28-32 degrees right?
