RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 05-08-2009 | 06:17 PM
  #10325
theradioflyer's Avatar
theradioflyer
Default RE: Wheeeeeeee.......... Blade CP!
Thanks a lot guys!
Jeff, that is an old vid with new music. Someone didn't like me using the previous song so You-tube cut the soound so I changed the music and reposted it on Vimeo. I still will NEVER, NEVER, NEVER chase any animals. Birds don't count
JPEE, that foam isn't very strong at all. That plane is depron and it snaps easily but with a little foam safe CA and kicker your right back in the air.
I knocked the nose off of it when I hit the ground today and I glued it back on with Gorilla glue. It takes longer to set but should be(hopefully) stronger.
I hope the rigid foam holds up to my abuse
Jim, I'm going to put a carbon fiber rod in the wing for a spar and prone weak points will get small rods as well. I can't wait to see your composite deck. Man that stuff aint cheap[X(] I looked at refacing my deck with it last year and passed The great thing about it though.... you only have to do it once and no maintenance. Worth the extra dough!
God Bless Y'all,
Jay
