RCU Forums - View Single Post - working on a poulan 32
Old 05-09-2009 | 01:25 AM
rangerfredbob
My Feedback: (13)
Default RE: working on a poulan 32
is it out of a blower or a weedie? those convert easy using the magneto ignition as all the prop adapter is is a spacer, with the shaft sticking through the prop and the stock nut with a washer holding it on... running on gas/glow can be a lot more compact, I would run a die down the crank then shorten it to your tastes, the cranks are just mild steel nothing fancy.
I still haven't ran either of mine, so I don't know how it'll run.
