RCU Forums - View Single Post - The Wings Maker Ultimate 40
Old 05-09-2009 | 03:02 PM
Greg Covey's Avatar
Greg Covey
Default RE: The Wings Maker Ultimate 40
The tailwheel assembly was complete and easy to install. I drilled 2mm holes for the screws and rudder hole. The holes were coated with some thin CA before installing the assembly and I used Pacer Z-42 thread locker on the set screws before tightening them. Remember to slide the one wheel collar against the plastic base before tightening it so that it helps absorb shock on landings.
ID:	1195106   Click image for larger version
