Field equipment questions
The voltmeters that are sold for rc applications are loaded for the proper loads consistant with rx's and tx's and will give readings more usfull for rc use. A standard multi=meter will do the same thing but needs to have the load built in to the probs.
I have had a bad experience with a field box bat powered glo=igniter. The bat was low and when the engine started the batt gave a voltage spike that burned the plug out every time. I used a whole card of plugs before I figured out what was wrong. Also using the power supply for the starter and glo=plug made for sometimes having low voltage to the plug and hard starting. I like to keep the power source separate for the plug and the starter
