ORIGINAL: BarracudaHockey
ORIGINAL: Rcpilot
I've got dual AR7000 RX's in a larger gas plane. The radio is a DX7.
Binding dual RX's is a piece of cake. Put the bind plug in the left RX and bind it. Turn it off and move the bind plug to the right RX. Bind the right RX. Remove the bind plug.
Fly.
Works perfectly.
Thats great if the recievers are the same OR the transmitter isn't capable of 2048 but when he binds the AR9000 with the 9303 its in 2048 resolution mode and then when he rebinds the 6200 it wont operate at 2048 so the transmitter shifts down to 1024, now when he turns them both on the AR9000 is expecting a 2048 signal and doesn't get it so it won't link or acts nutty.
It would be fine if it were a DX7 that doesn't transmit in 2048 mode.
If it were a DX7SE he'd have the same problem.
True.
I posted so that guys with a DX7 and AR7000 would know it IS possible to do it on that system.
