Originally posted by Stick Jammer
You can use an iron with a sock set on LOW. Just try it on a scrap piece first if you have one. I have applied MonoKote to painted surfaces but you can't leave the iron in one spot too long or it will start to melt the paint.
Ok sounds good. Guess it doesn't matter the type of paint does it? I used Krylon primer and paint. 2 coats primer and 3 coats white paint.
