Your BUGGY and SETUP
Copied this from the Truggy forum where its a Sticky, great idea maybe we
can get this going here and the Mods will sticky it
Ok Lets hope this thread works and for once put an end to all the most commonly asked questions about what setup, what diffs, what servos. I'm sure I'm missing a lot of specs but thats all I can think of right now so feel free to add a spec or two in your data.
Let me start it off:
Here's the blank template you can copy n' paste this with your info in it:
BUGGY :
THR SERVO :
STR SERVO :
MOTOR :
PIPE :
RADIO :
CLUTCH :
CB :
WHEELS :
DIFFS F/C/R :
SPRINGS F/R:
SHOCKS F/R :
DROOP F/R :
RIDE HEIGHT :
CAMBER F/R :
WING:
ADD INFO MODS ECT:
TRACK READY WEIGHT:
Here's my configuration:
BUGGY : AE RC8
THR SERVO : AE 1015
STR SERVO : AE 1015
MOTOR : OS V-Spec
PIPE : TT 2035
RADIO : SP DX3
CLUTCH : JP ALUM 1 BLACK 2 GOLD SPRINGS
CB : 16T
WHEELS : MP9 OR LOSI
TIRES F/R : AKA CITY BOCKS SOFT OR IBEAMS IN SOFT, AKA INSERTS
DIFFS F/C/R : 5/5/5
BARS F/R : SILVER/SILVER
SPRINGS F/R: SILVER/SILVER
SHOCKS F/R : 1.4X2 1.2X2 PISTONS FRONT AND REAR, 40WT BELOW 70F, 45WT 70F-90F MAYBE 50WT IF ITS BLAZING OUT
DROOP F/R : NONE, SHOCKS HAVE 2MM FRONT AND 5MM REAR LIMITERS
RIDE HEIGHT : 29MM/29MM RC8s are very sensitive move slowly in 1/2 mm increments
CAMBER F/R : -1.5/-1.5
WHEELBASE : MEDIUM
CASTER F/R : 16
TOE F/R : +1 / -3
WING: FORWARD AND LOW, STOCK AE
ADD INFO MODS ECT: RX BATTERY RELOCATION, EMULSION SHOCKS WHITH RTR CAPS, STEERING MOD.
HINGE PIN BUSHING 1F/2R DOWN, KICKUP 2UP, ANTISQUAT 3DOWN.
TRACK READY WEIGHT: 3705 GRAMS
This is all pretty simular to the last Team Setup before they went to Big Bores.
