RCU Forums - View Single Post - Servo push rod types
Old 05-11-2009 | 06:39 AM
Andrewmc
Default Servo push rod types
I have sullivan Gold'n' Rods installed in a plane and had the trims neutral with neutral control surface deflection (rudder and elevator).
Yesterday was a warmer day than recent days have been and when I took off the plane climbed steeply. It took almost all of the available downtrim to maintain level flight, the rudder trim also had to be significantly adjusted.
I have put this down to the expansion of the push rod inner with the higher ambient temperature.
I propose to remove the yellow inner rod and replace it with a length of threaded metal rod inside the red sleeve.
Will this remedy the problem?
Daily temperature diference morning to afternoon can be quite significant at times and I expect this will be an ongoing issue.
