RCU Forums - View Single Post - Importance of engine break-in ?
Old 05-11-2009 | 06:49 AM
  #60
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Importance of engine break-in ?
The thing is, the carburetor/tank relationship effects tuning. If you run an engine on a bench, you've already established one engine/tank relationship, and you've tuned accordingly. When you transfer the engine to the plane, you can try your best to get the tank on the same level. Invariably, the setup will differ in some subtle way, and you'll have to retune all over again. You're duplicating your efforts. Why not establish the correct carburetor/tank relationship once, in the plane, and then leave the mixture alone forever? Its one less variable to contend with.
What if I decide from the bench running I don't want that engine in that plane? What is so hard about retuning? You want to kill the fun? Also on the bench I can move the tank up and down and duplicate the position in the plane.
