RE: Servo push rod types
It is humidity as well as heat that causes changes in nylon rods. You can solve the problem with Sullivan carbon-filled pushrods- they are absolutely stable. If you want to use metal pushrods don't install a thick,heavy threaded rod, but use a smaller diameter music wire rod with soldered connectors at the ends. The plastic outer tube will provide the rigidity.
