RCU Forums - View Single Post - Stryker Mods From The Darkside Part 2 (Bullet Proof A Stryker)
Old 05-11-2009 | 09:11 AM
  #48
critterhunter's Avatar
critterhunter
Default RE: Stryker Mods From The Darkside Part 2 (Bullet Proof A Stryker)
After the BP21 (2408-21) a year or so later the 2409-12T came out and was very popular among Stryker owners. It provided really good speed and unlimited vertical with plenty of torque. I ran an 8x6 APC E prop on this motor. This is over propping it and drew about 30 amps. I would not suggest running anything bigger than an 8x6 because that’s already red lining the motor. I think anything bigger will push it over the edge.
NOTE: The 2409-12D is a better design (not a bell style) and, even though the specs are the same, it can handle more amps due to it’s build. I would suggest anybody considering this motor to go ahead and opt for the D version since it’s only a few dollars more. I’ve also read of people running I think 8x7 props or bigger on the D without overheating it. The more solid construction helps bleed off any heat better.
TowerPro Brushless Outrunner 2409-12T
http://www.hobbycity.com/hobbycity/s...idproduct=2046
This motor is excellant value for the price. 200 watts for less than $10! I fly this motor on my F-27 Stryker and it has been radar gunned at 82mph. I use a BM2409 motor, 7x6 APC prop, 35Amp speed control and United hobbies 3S1P 2200mah 20C Lipoly battery. 190 watts in a 20oz plane. That is about 140 watts per pound! The short, thick shaft takes a beating and has not bent yet! Mine has 100+ of flights on it . I now own 4 of them and my flying buddies have a bunch too! Put this motor in any 16-30oz plane for great power to weight performance. I know a group of flyers who are racing GWS Formosa's with these and are rippng up the sky. Great motor. Great price. No problems.
I use this motor in my F27C Stryker and with a 3-cell LiPo battery, it flies fantastic! Unlimited vertical.
I used the stock motor mount with a 2-liter soda bottle cap to mount the motor. What a great motor.
The motor does get warm after flights, but only really hot on warm days.
I use a 7x5 prop with this motor. Just great
put this on my stryker b model took the base off and epoxied it to the stryker mount then put motor back in the base and it lined up nicely.ran a 7x4 apc prop the plane launched nicely and went vertical easily.straight speed guess is maybe 50-60
Got this one as combo, very good deal and this CD-ROM motor performs better than many others. I put it on static thrust test. Look for yourself on these data.
GWS9050HD 2-blade 17A,7V,123W,25oz,203oz/Kw
GWS9050HD 2-blade 18.35A,7.5V,139w,26.8oz,193oz/kw
GWS8040 3-blade 14.57A,7.48V,105W,21.1oz,201oz/kw
GWS8040 3-blade 15.24A,10.5v,160w,163oz/kw
GWS8040 3-blade 14.57A,7.48V,105W,21.1oz, 201oz/kw
GWS8040HD 2-blade 11.67A,7.41V,84w,18.3oz,218oz/kw
2/28/2008 PFU
This motor is great. 3s 9x5 gets hot. 2s gave me the better results on 8x5. Pleanty of thrust and 7 min of flight time for 1100Mh 2s. Reduced throtle to 60% and I get 11 minutes.
Hi,
I take this motor for the UH (HC now) P40 results with power analyser :
with UH 8*6 APC Style :
22A 280W 11.1V 1700 10/15C
28.5A 325W 11.1V 2200 20/30C
With UH 9*6 APC style:
29.2A 300W 11.1V 1700 10/15C
Don't make with the 2200 20/30C for don't burn the motor !
I give on the 1700 10/15C 11.1V with the 8*6.
Very good motor with very hight thrust !!!!
Installed on a 100% 25oz AUW Super Bandit. Gives 30oz thrust with 7x5 APC drawing 20A/220W on a 3S2100 15C. Cut a groove or ride a fast rail with this one.
Great little motor for the price. It handles loads upto about 30A (full throttle at 3S using a 8x6 prop) without overheating. There 9x6 is too much so don't try!
I use 2 of these on my twinstar and they give near vertical performance. Topspeed is around 130km/h in this configuration
