RE: 8611 problem
Jeremy,
I've got a load tester where that I could plug into one of the ports on your powerbox that will give a voltage reading under loads up to 3 amps.
I'll bring it by later this week when I'm back in town and we can run a test. This should tell us what the actual regulated voltage is coming out of the powerbox under loaded conditions.
I read somewhere some time ago that increased supply voltage to servos reduces the neutral deadband of the servo making it more sensitive around neutral. Problem is I can't remember or be sure of the source and it may only apply to analogue and not digital servos.
Is the voltage setting of the 40/24 adjustable?
PaulD
