RCU Forums - View Single Post - Can someone give me some tips on flipstarting an engine.
Old 06-20-2003 | 03:54 PM
BackAfter20
Default First tank on the ground
Originally posted by ykol20
im gonna go slow, just to run a tank through it, make sure everything works, its a great planes lancair.
Breaking in engines is usually done at full throttle, running rich. Slowly taxiing around would not be possible at those RPMs. Trying to break in an engine at idle will not allow the engine to reach proper operating temperature, and could cause premature wear. There are many threads on this subject in the engines forum.
If you don't want to remove the engine from the plane, firmly supporting the plane will be necessary for proper engine break in.
Like FLYBOY said, just don't want to see you ruin your nice plane (or new engine).
(JMHO)
