RCU Forums - View Single Post - Engine overheating??
Old 05-11-2009 | 10:18 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Engine overheating??
ORIGINAL: chrome350
The engine is on a plane that has been flown for about 2 years. Same cowl, cooling never a problem. 15x14w apc prop, OS plug, 30% CoolPower fuel. Checked all the bolts on the engine, and the fuel lines. Tried a new gallon of fuel. Richened the needle valve. Could it be the bearings??
Larry
You might try a 15 X 4W prop and it would run cooler?
If it ran OK in the past, you may have a bad bearing?
