RCU Forums - View Single Post - Echo engines cut crank, plug block.
Thread
05-11-2009 | 10:38 PM
3
andrew66
Jan 2006
1,057
Brandon, MB, CANADA
RE: Echo engines cut crank, plug block.
wouldnt this put more stress on the front main bearing? What if you were to cut the shaft so it still uses the other bearing, and have a shallow plug pressed in just where the seal is.
Reply
Like
andrew66
View Public Profile
Send a private message to andrew66
Find More Posts by andrew66
View iTrader Profile
