RCU Forums - View Single Post - Echo engines cut crank, plug block.
Old 05-11-2009 | 11:07 PM
av8tor1977's Avatar
av8tor1977
Default RE: Echo engines cut crank, plug block.
Yes, I definitely still use the rear bearing. The plug is shallow and just replaces the seal. The crank is cut so that it still fully enters the rear bearing.
I doubt if one could measure a power difference just from the seal drag, though the seal drag is noticeable when you turn one over by hand without the piston/cylinder installed.
AV8TOR
