RCU Forums - View Single Post - Why does it always happen to the good ones??
Old 05-12-2009 | 10:07 AM
  #76
invertmast's Avatar
invertmast
My Feedback: (23)
Default RE: Why does it always happen to the good ones??
ORIGINAL: SinCityJets
ORIGINAL: arizonasun25
ORIGINAL: Ali
Yes I was only using one Rx Same reasons as above really.
I have not had a chance to look into that
Do some people use more than one receiver (aside from the satellite's)?? How would you even wire that up on a turbine?
Chad
Chad,
If you use a power box royal it has a 2 reciver hook up. Wayne just installed one in my air world mig 21 2 futaba 14 channel recievers 2 batteries pretty much 2 of everything.
Ron
So you could plug in two spektrum receivers to it and they would both bind to the radio at the same time?
correct, you just put the bind plugs in both receivers and bind like normal, and both rx's link to that particular model.. or so i'm told
