RCU Forums - View Single Post - Cleaning plane
Old 05-12-2009 | 10:38 AM
Gray Beard
My Feedback: (-1)
Default RE: Cleaning plane
ORIGINAL: jetmech05
DO NOT USE WINDEX WITH AMMONIA......You said in your post that you have monokote.....ever hear of the wet method of applying monokote on monokote? You spray the area that you want the design on, with windex.....the windex allows you to move the design around. Once the design is in place squeege out the windex and let dry..go over with an iron......the point is that the windex with ammonia activates the glue..and design is stuck down...not like with heat put pretty good....if windex with ammonia activates the glue.....it will surely loosen the glue when it is stuck down...how many airplanes have you seen where the trim is loose?....Used to happen to me as well...not since I switched to alcohol.....and its cheap too...Good Luck
When I stated this a while back I was told I was full of castor beans!!! Glad other people have figured this out!!! Either that or there are more people eating castor beans???
I only use ultracote so no problem unless I have some mono trim, that has been known to happen.
I buy the really cheap window cleaner then juice it up with more alcohol. My planes have there mufflers deflected so I don't get a lot of engine snot all over so clean up is usually pretty easy. The after market long exhaust deflectors pointed in the right direction will help in blowing the snot away from the plane and help the nasty clean up. The OP can give them a try too.
