RCU Forums - View Single Post - LED failure on EQ6
Old 05-12-2009 | 04:58 PM
rrritchey
Default RE: LED failure on EQ6
Hi,
No, that is not a problem, your outputs on the unit are just out of order. The power leads are ALSO channels. Even if you plug the first power lead into throttle you can still use the output on the side for that channel.
