RCU Forums - View Single Post - GST 7.7 engine problems
Old 05-12-2009 | 06:44 PM
chrobar
Default RE: GST 7.7 engine problems
Did the owner properly break in the engine yet? If so, return it to stock settings if you have not done so already. If the glow plug screws into the block without problems, it's probably OK. Also check the idle gap in the carb. It should be about 1-2 mm out.
