ORIGINAL: ckangaroo70
I got a chance to run and dial in my Ryobi 31 again today swinging an APC 18x6W. I was getting a good 6900-7000 RPM! I thought those were pretty respectable numbers for a stock unmodified 31CC Ryobi single ring with the Zama carb. I am running 89 octane mixed 40:1 with Klotz technoplate oil. It is the same oil I use to make my Nitro fuel and it is 80% synthetic/20% Castor. The Ryobi really seems to like it, but lawnboy ashless or Penzoil 2 stroke oil probably do just as well. The best reliable idle I could get was around 2200 RPM. I was hoping to get down to slightly under 2000, but 2200 probably be ok with a 6 pitch prop. If I was using an 8 pitch it might be hard to get the plane to slow down. Anyhow I just thought I would post my results. Now I just need a good day to take the Rascal out and test it in the air.[8D]
I just aquired another Ryobi weedeater, but this time it had the single ring 28.5cc short shaft Ryobi on it. I am in the process of getting it converted now, and will probably stick it on a Super Sportster 90/120 I am scratch building. This one has the Warlbro Carb instead of the Zama like my 31. Be interesting to see how the two stack up against one another.
If you make your own glow fuel, then you will have the ingredients to make gas/glow if thats your cup of tea. I think thats the only mod not covered. It would be kinda interesting to see the increase from stock gas to gas/glow, and modified gas to gas/glow.
