RE: Motor equivalency questions
Look for a motor with similar dimensions and kv rating. It may not be exact but it will be close. You'll also want to compare Watt ratings. a lot of times ARF's from GP, E-Flite and others come set up to use their specific motor. That doesn't mean you can't use a different motor of course but it may require you to a do a little "engineering" on your own.
