RCU Forums - View Single Post - battery discharger
Old 05-13-2009 | 11:29 PM
ChuckW's Avatar
ChuckW
Default RE: battery discharger
Yep, just give them a good charge the night before you go flying and don't worry about much else. Even modern Nicads don't need regular cycling like they used to. Like I mentioned earlier, I only cycle periodically to check battery capacity but I have quite a few planes now and they are getting larger and more expensive, I like the piece of mind.
Before investing in a cycling charger (which I recommend at some point if you stick with the hobby) I would get a good expanded scale voltmeter which applies a slight load for checkign battery condition between flights. This could save an airplane.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWDZ5&P=7
