RE: New JetJoe J-Junior 4lbs turbine
hi Jamie, I have also looked at the Eflite Hawk for my lambert, I am sure it would work. So far I have installed the lambert in a HET phantom, and a HET F15, both had retracts and flew very well, the phantom was a pocket rocket and the F15 was surprisingly docile.The asymetric thrust in the F4 caused it to crash, but not before some rewarding air time. It would be nice to install the turbine with out a thrust tube,as far rearward as possible, but with such light weight electronics,bat and pump, it would be near impossible to balance.I have ordered a JJ junior and a vortex32 for my next project,because the Lambert has found a new home in my stryker,which is one fun plane!.It must the most relaxing turbine plane I own.I look forward to your choice of airframe.
