RCU Forums - View Single Post - Flying Cat 90
Old 05-14-2009 | 08:20 AM
flyingscubakev
Default RE: Flying Cat 90
Yes this is an ARF. My main concern is the amount of work I'm going to have to do to fix the retract positioning. Even the pre-drilled holes in the horizontal stab that mounts on top of the tail fin are offset from centre, as well as so far forward that if I use those holes the top of the rudder will hit the elevator and limit it's deflection. I'm of the opinion that there wasn't much care or QA taken when building this model[].
Kevin
